Tom's Hardware > Forum > CPU & Components > CPUs > noobie question... need help
Forum CPU & Components : CPUs - noobie question... need help
first time computer builder, here, so this will probably seem like a stupid question. If I buy a boxed processor (either XP or P4) from either Intel or whoever makes the best AMD chip, will it come with a cooling unit? If not, is there anything I should know when purchasing a cooling unit?
furthermore: I saw the debate on XP vs P4. are you guys taking into account Rambus memory? If I got a P4, it would only be the i850 chipset, cause I want the Rambus, even though it is expensive. (to me, it's cheap, cause the last time I bought RAM, it cost a little more than 50 cents a meg) Is RDRAM available for Amd chips? if not, does it matter? furthermore, are there any compatibility issues with amd and any software, (specifically 3d, Maya, 3dsmax, etc...) sorry for all this. help if you can. thanks.
Sponsored Links
A retail boxed processor from either company will come with an HSF unit sufficient for normal use. OEM processors do not. You may want something larger than the "stock" HSF on retails if you overclock, but if you want the 3-yr warranty, you need to buy the retail part and use the retail HSF.
For OEM processors, you need to buy a separate HSF. Some are crap, some are good. I typically head over to <A HREF="http://www.anandtech.com/" target="_new">AnandTech</A> for HSF reviews.
<i>If a server crashes in a server farm and no one pings it, does it still cost four figures to fix?
Reply to Kelledin
Only AMD makes AMD chips.
If you buy a retail CPU, then you will get a heatsink and fan regardless of whether or not it's an Intel or AMD CPU. Make sure you carefully read the instructions before installing it.
If you're a first time builder the retail heatsink and fan is probably the best option for you.
When we talk about the XP vs. P4 issue, we always consider the available platforms (motherboards, chipsets, and RAM). At the moment AMD offers the best price/performance.
If you decide to go with a P4, Rambus is a good choice.
You can't currently use AMD CPU's with Rambus RAM, however AMD CPU’s work perfectly well with DDR RAM.
There are no compatibility issues the AMD CPU's and any software.
"Ignorance is bliss, but I tend to get screwed over."
Reply to somerandomguy
I am also looking to upgrade, and I've been following Tom's Hardware for several months. This K6-2 is on an old baby-AT motherboard with socket-7 technology, so I have to pretty much upgrade everything!
The performance-to-cost leader is the Athlon XP, with a shown speed of 1600+ up to around 1800+. The cost escalates too fast beyond this point. If you get an AMD, mate it to DDR memory, and opt for the newer PC2700 if you can. It will work just as well at PC2100 rates and allow you a little more headroom to upgrade with later.
If you prefer "tried and true" safety, then the P4 with RDRAM is the lead choice. Should the CPU overheat, it will slow itself down rather than burn out, a point made popular by THG several weeks ago.
AMD K6-2@500MHz... takes a lickin' & keeps on tickin'!
Reply to Anonymous
Quote :
Not only does amd have no compatability issues with any software, the 3d rendering software you mentioned is one of amds strongest points. An amd chip will out perform a signifigantly more expensive and mhz faster p4 in those applications.
"The Cash Left In My Pocket,The BEST Benchmark"
No Overclock+stock hsf=GOOD!
Reply to Matisaro
There are 1072 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
