This is first my experience starting with nothing but the motherboard, and you guys are giving me a serious education. I had several lazy-minded misnotions.
First and foremost, you disabused me of the notion that motherboards came out with chipsets and surrounding support chip infrastructure that was almost as limited by timing as were the processors that it supported. Sure, I knew that motherboards have a greater timing range than the CPUs themselves have, because the motherboards obviously support a range of CPUs at different speeds, but I didn't realize how resilient the board itself was at running at much higher speeds.
At least in this board's case, it's the changes in voltage as you go to higher speed CPUs, for which it was not originally designed to handle, that matters the most. And I trust that stability is not a problem because you both have obviously been doing this for a long time.
More Questions (As Long As I Can Continue To Lure You Into Giving Me All Of This Incredibly Good Info :O) ...
This board is supposed to soft-switch its operating characteristics to accomodate whatever CPU that you plug in to it, so that one does not have to fiddle with dip switches. I'm curious how it manages to adapt appropriately when I begin putting 1.2GHz Celerons on it. Powerleap has confirmed that it's compatible. Yet, being a software guy with little experience at this, I'm just very amazed / impressed. It seems like I would have to do some additional magic in the BIOS settings, or to do *some* tweaking *somewhere* of some sort, because of imperfect assumptions by the CPU identification / auto-calibration firmware.
Also, if I manually override the volatage, as you suggested I do if I want to try Coppermine processors, do all of the other automatic adaptations work properly?
Finally, rather than tell me which you would choose, NON-Coppermine or the 1.2GHz Celeron, you've given me back Coppermine CPUs as yet another option. If it were you, which of those options would you choose, assuming stability was very important?
I can't tell you how impressed I am with this web site and with the folks who "hang here". You've been fantastic.
Much appreciation,
MJS
<P ID="edit"><FONT SIZE=-1><EM>Edited by mstrong4867 on 02/11/02 08:15 AM.</EM></FONT></P>
