Unusable free space problem on the disk
Hello, there is a free space partition on the hard disk got created which i am not able to use it can't be located on the drive also please provide any suggestion
1 answer Last reply
More about unusable free space problem disk
  1. Do you mean there is "unallocated space" on the drive?
    If yes, it is not a partition at all. You have to create a partition there using Disk Management:
    Control Panel > Admin Tools > Computer Management > Disk Management
    Right-click the unallocated space and choose "Create new simple volume".
    When the new partition has been created (it only takes a couple of seconds), right-click it again
    and choose "Format".
Partition Hard Drives Free Space Windows 7
