Shutdown problem
my window unexpected shutdow when i work on the laptop
i have window 7
please tell me what should i do for best result
1 answer Last reply
More about shutdown problem
  1. Is the laptop overheated? If so, it will shutdown so that it doesn't fry. You may need to clean it out (if if has a lot of dust and hair in the fans). And set it on a flat surface not your bed/lap so that it can get enough air flow. If it's not a heat problem, give more details.
Configuration Laptops Shutdown Windows 7
