Hey Tom's Hardware,
It's my first time posting, and I’ve been having some BSOD issues for the past two weeks, there’s a bit of a story but I’ll try keep it short. I hope this is the correct place to post.
About two weeks ago I was getting BSOD called MEMORY_MANAGEMENT and PAGEFAULT IN NONPAGED AREA. These I googled they could possibly be related to RAM, so I took out one RAM stick and it worked! I tried the other and eventually got a blue screen. The blue screen would usually take like 30min or happen quickly while gaming. So about a week later I got my RAM replaced no hassles.
When I put the new RAM in the computer’s fans started light came on and it turned off, it did that twice then it posted, but with a different black screen with small white writing, with BIOS options. I guess it was to be doing with the new RAM?
Anyway, it was all working fine until a few days later and I get a BSOD when I turn my computer on in the morning, IRQL_NOT_LESS_OR_EQUAL. Restarted the computer and I tried to do a system restore but that failed. So I swapped the RAM sticks around and got that black screen again, different BIOS screen with some options. I got back into Windows and eventually BSOD again, this time “Driver corrupted pool memory used for holding pages destined for the disk”:
STOP: 0x000000DE (0x000000000000002, 0xFFFFF8A00AFC06F8, 0xFFFFF8200AFC06F9, 0x000000009F1C28C0)
The computer kept revving and wouldn’t turn on, I left it for 30min then it was fine for a couple of days. Until today, I just got SYSTEM_SERVICE_EXCEPTION:
STOP: 0x0000003B (0x00000000C000001D, 0xFFFFF88001A1AC03, 0xFFFFF8800BC979C0, 0x0000000000000000)
I don’t know where to find the dump files sorry.
GPU: Gigabyte 2G 7870 Overclock Edition
CPU: i5-3570K
SSD: Samsung 840 120GB
HDD: Seagate Barracuda 2TB
Motherboard: AsRock Z77-Extreme6
RAM: Patriot Viper 8GB Kit DDR3
PSU: Corsair TX650
Thanks,
Matt
CPU: i5-3570K
PSU: Corsair TX650
Thanks,
Matt
