Laptops speaker makes a funny noise when u click
my laptop speaker makes a noise, it sounds like air through a mic that comes out of a speaker, and when i rub my hand against the back of the screen, then u can hear me rubbing my hand from the speaker. and when i close my screen my laptop makes a loud beep, what should i do??
1 answer Last reply
More about laptops speaker makes funny noise click
  1. You should disable system sounds and I hope your mic is not somehow on :P
Acer Laptops Speakers
