Installed Linux Mandrake - HD problem!!
Last response: in Linux/Free BSD
I installed Linux Mandrake 7.2 on an empty FAT32 partition on my hard drive, using the complete installation partition. However, after installation, the hard drive will not work at all! The BIOS recognizes the hard drive, but as long as it connected I can't boot *anything*. Not even with a floppy. Any suggestions or hints? I can't fdisk /mbr, since I cannot load anything as long as this hard drive is connected.
It's a longshoot, but did you check BIOS for boot order? Maybe it's harddisk only? Try to change it.
P.S. You are not using U-ATA/100, are You?
And they said schizophrenia is annoying?
Ask the community
