Tom's Hardware > Forum > Systems > Dell > Flash Inspiron 3800 BIOS Without Battery Installed
Forum Systems : Dell - Flash Inspiron 3800 BIOS Without Battery Installed
Archived from groups: alt.sys.pc-clone.dell (More info?)
does anyone know of a way to flash the bios on an inspiron 3800 that does
not have a battery? the packaged and unpackaged versions of the flash bios
utility halt when they find that no battery is installed. and there does
not seem to be any command line switches to use with the unpackaged utility.
any workaround would be greatly appreciated.
thank you.
Sponsored Links
On Fri, 15 Oct 2004 16:07:42 GMT, Christopher Muto wrote in
<news:iBSbd.194$B34.89@trndny02>:
It's probably a safety "feature" on your laptop to ensure there is a steady
supply of power while you do the BIOS flash. Did you lose the battery?
Dave
You can talk about us, but you can't talk without us!
US Army Signal Corps!!
http://www.geocities.com/davidcasey98
Remove IH8SPAM to reply by email!
Reply to Anonymous
I don't know if this is a just a safety measure, or is not even possible.
I have heard of a /forceit option when executing the flash. Another option
I have seen is /jabil when forcing it to flash when it thinks it has an
incompatible BIOS update -- maybe try it if the other option does not work?
Since these batteries are available on eBay for only $40-50, it is probably
not worth the risk of damaging your system.
"Christopher Muto" <muto@worldnet.att.net> wrote in message
news:iBSbd.194$B34.89@trndny02...
> bios
> utility.
> thank you.
Reply to Anonymous
There are 854 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
