Repair wii fi network connection on motherboard
scm2814
Have a Acer 3680 and am not able to find a wireless connection, have tried repair and still no connection. the only way to connect to the internet is by going hardwired. can you help :)
Seeto
20
These are the specs for the Acer 3680 series
Acer Aspire 3680 Specifications
have you checked Device Manager?
it could as simple as a faulty driver.
I sorted out similar problem on a friend's laptop by rolling back the driver to a previous version.
it connected fine after that.
if that doesn't work then it must be a hardware problem.
