Wanted to upgrade my system from an Athlon 1400 to and Athlon-XP 2100.
I am running on a KG7-RAID with latest BIOS, here is bios detail.
Filename: KG768.EXE
Date: 01/28/2002
NOTE:
Support AMD AthlonXP 2000+ and Morgan Duron 1300 CPU.
Fix ACPI error message in Windows XP Event Viewer.
Support 3.5GB memory while four sticks of 1G DDR memory installes.
Fix performance drop after STR mode by Sisoft Sandra 2000.
Update HPT370 BIOS to 2.0.1024.
Support 48 bit LBA for HDD larger than 137GB.
Change the default year to 2002.
Thanx for any help..
Filename: KG768.EXE
Date: 01/28/2002
NOTE:
