Tom's Hardware > Forum > CPU & Components > CPUs > Power Supply Question
Forum CPU & Components : CPUs - Power Supply Question
Is 350watt enough... in what case would you need a 430 watt Power Supply..
Once you go AMD, You never Go back!!
Sponsored Links
Enough for what? It depends on what your running. However 350W should be enough for most things. The next step up would be 400W.
Sure eagles may fly, but weasels don't get sucked through jet engines
Reply to Anonymous
Please list your system specifications. Include the processor, number and types of drives, video card, and any other special considerations.
Thanks,
-Raystonn
= The views stated herein are my personal views, and not necessarily the views of my employer. =
Reply to Raystonn
- 0 +
It depends on the system, but for the best stability and long term reliability you might want to consider a 400W or above. This used to not be a problem, but current systems need a lot of juice.
I often link to pcpowerandcooling.com since they have a table of average power consumption from PC components. You basically want to add everything up and then make sure that your psu isn't stressed beyond 70%.
It also depends on what rails you'll be using. Each power supply is different.
<font color=red>If you were to have sex with your clone would that be considered incest or masturbation?</font color=red>
Reply to dhlucke
There are 1225 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
