Tom's Hardware > Forum > CPU & Components > CPUs > Silicon Base Thermal Solution
Forum CPU & Components : CPUs - Silicon Base Thermal Solution
Is it safe to use silicon base thermal solution on a Pentium III Coppermine CPU?
Also, I would appreciate any opinions on the Thermal Take FC0370 Golden Orb Heatsink/Fan. Thanks in advance.
Sponsored Links
i hope you wont hate me for this, but the golden orb sucks. other than looks its got nothing good. and yes you may use Silicon Base Thermal past. it is safe, just alpy a thin layer that would be sufficient.
<b> <font color=orange> Forum police </font color=orange> </b>
<font color=blue> Here to preserve respect and friendship </font color=blue>
Reply to scamtrOn
Is it sufficient for a PIII 933 Mhz, not overclocked?
Thanks again.
Reply to Anonymous
sure, but your temp will be higher than other PIII 933Mhz. did you buy one? if not you can get a much better fan for about $17.
Reply to scamtrOn
yes, I have one, but in light of this information, I think I'll get a new fan. Which fans do you recomend?
Reply to Anonymous
<A HREF="http://www.newegg.com/app/ViewProduct.asp?submit=list&catalog=62&DEPA=1" target="_new"> here </A>
look at all the socket 370 cpu fans.
Reply to scamtrOn
There are 540 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
