Toshiba laptop wont turn on HELP!
Ukranian20
24
Problem is that when connected to the power adapter the LED comes on indicating that it is plugged to the mains and with the battery put in the battery LED light also comes on but as soon as I press the power switch to turn on the laptop, the lights all go off. Please I will like to know if you guys can suggest a solution to this. The laptop wont turn on at all. I also tried holding the power button down for 30 seconds with no battery technique and that didnt work.
Ukranian20
24
Yea i tried that
ricky_critic
183
Hi,
If the laptop battery is not charging the laptop in a proper way it will not start.
The first step you must take is to check the condition of the battery and if it is able to get charged properly.
Check if the laptop’s LEDs are lit. If they are not it means that the problem is caused because of the battery.
Check if all cables are correctly connected.
Plug in the battery into another outlet.
Anyway in case of a damaged battery the solution is replacement.
