Screen display problem
coolcurrent
My laptop does not display the screen up to the taskbar area, it does not show the taskbar at all.
Whn i boot, the first boot screen (loading windiws) shows well. but as soon as it shows the startup light blue screen, the word bottom seem elongated that th screen.
please see the attached. i ahve updated my drivers using drivermax but still the same
any idea what could be wrong?
coolcurrent
when i boot up in safe mode, the screen looks ok. Out of curiosity of a possible bad driver, i reformatted the laptop . it looks ok at the default 640 x 480 screen resolution, when i boot up. But when i change the resolution to anything higher, the problem at the onset appears. when i revert back to 640 x 480 screen resolution,, the creen looks ok again.
so am guessing its driver issue. where can i get the drivers for insyde cs553x
coolcurrent
on the body of the laptop is written Omatek, but whe i do systeminfo in command prompt, i see
system manufacturer: insyde
system model = cs553x___
coolcurrent
