I Indifferent- Distinguished Aug 1, 2011 8 0 18,510 Aug 11, 2011 #1 Hey Should I Remove the battery in my laptop when I'm at home and just keep it plugged in? or does it not matter? Just bought it yesterday
Solution jaguarskx Aug 11, 2011 I remove the battery after it is fully charged for my new laptop. If I know I will be taking it out with me, then I'll stick in the battery about an hour before just to make sure the battery is topped off. In the event i don't need to take my laptop out with me, then I'll just make sure the battery is charged to full capacity once a month.
jaguarskx Titan Apr 19, 2006 27,979 3 84,965 Aug 11, 2011 Solution #2 I remove the battery after it is fully charged for my new laptop. If I know I will be taking it out with me, then I'll stick in the battery about an hour before just to make sure the battery is topped off. In the event i don't need to take my laptop out with me, then I'll just make sure the battery is charged to full capacity once a month. Upvote 0 Downvote Solution
I Indifferent- Distinguished Aug 1, 2011 8 0 18,510 Aug 11, 2011 #3 jaguarskx : I remove the battery after it is fully charged for my new laptop. If I know I will be taking it out with me, then I'll stick in the battery about an hour before just to make sure the battery is topped off. In the event i don't need to take my laptop out with me, then I'll just make sure the battery is charged to full capacity once a month. Thank you!. I know my laptop will be sitting here until september when school starts so I guess I will remove the battery! Upvote 0 Downvote
I Indifferent- Distinguished Aug 1, 2011 8 0 18,510 Aug 11, 2011 #4 Best answer selected by Indifferent-. Upvote 0 Downvote
