Floppy does not work after building new system
Hi!
After I built my new system I have had problems with getting my floppy disk drive to work. When I try to access it windows says that the floppy disk is not formatted. Sometimes I get an error message that says that there is an O/I error. I have checked that the flat cable is inserter correct. I have tried all four ways anyway. I have tried making some changes in BIOS. The only thing I have found that could make any difference is the option to enable/disable “boot up floppy seek”. I get the same error message either way. I have had the same problem with the three systems I have built.
/Johan
EPoX 8KHA+
Athlon XP 1800+
ATI Radeon 8500 Retail
IBM 120GXP
SB Live! Player 5.1
Hi!
/Johan
EPoX 8KHA+
Athlon XP 1800+
IBM 120GXP
SB Live! Player 5.1
