Help! C:\$Extend\$UsnJrnl is corrupt and unreadable. Please run the Chkdsk utili
Hello,
C:\$Extend\$UsnJrnl is corrupt and unreadable. Please run the Chkdsk utility'
When re-installing windows, i can not format the partition and if i try to load the computer the error missing boot shows press alt etc,
any ideas ?
1 answer Last reply
More about help extend usnjrnl corrupt unreadable chkdsk utili
  1. Boot from your Windows 7 System Repair Disc (which you should have made when your PC was working okay) and follow these directions to run the Check Disk utility: https://kb.wisc.edu/page.php?id=6565
    You can also boot from a Microsoft Windows 7 DVD if you have one.
Drivers Chkdsk Partition Windows 7
