Yes No
Ads
Tom's Hardware > Forum > Applications > Multimedia > VCD made by Nero have sound problem
Forum Applications : Multimedia VCD made by Nero have sound problem
I just capture some video from my DV and I use Nero 5.8 to convert it into a VCD. When I paly the VCD on my computer, the sound will come out later than the video. Why.
Reply to raylee011
Did the problem happen to the captured video before you converted it into vcd? BTW, Nero 5.8 has been released already?
Reply to elzt
No, it didn't happen while it was in AVI format.
Reply to raylee011
- 0 +
The problem might have to do with Nero which isn't very good at encoding Mpeg videos. I suggest you convert your AVI files to MPG files first using other "good" software. Then you can use Nero to write the Mpeg videos directly onto a VCD.
Reply to elzt
I did that and it fix the problem. But the picture is not as good. What other software would you recommand.
Reply to raylee011
- 0 +
Many NLE software such as Premiere 6.5 are pretty good converting AVI to MPG format. But those software are expensive and take up lots of your system's resources. In other words, they are s-l-o-w in converting videos.
I recommend a free software called TMPGenc which I'm using now for making Mpeg1 videos. The pro version (which extends the conversion capability to Mpeg2) is not free though. Here is their official site:
<A HREF="http://www.tmpgenc.net/e_main.html" target="_new">http://www.tmpgenc.net/e_main.html</A>
And this web page will guide you through step-by-step on using TMPGenc:
<A HREF="http://www.dvdrhelp.com/tmpgenc.htm" target="_new">http://www.dvdrhelp.com/tmpgenc.htm</A>
Actually this same site provides lots of other helpful info on video conversions.
<A HREF="http://www.dvdrhelp.com/convert" target="_new">http://www.dvdrhelp.com/convert</A>
Good luck and have fun. :)
Reply to elzt
- 0 +
I've had the same problem. As far as I can tell it's either that Nero is not good for encoding VCD's or my 1Ghz CPU isn't pulling enough weight.
<font color=red>GOD</font color=red> <font color=blue>BLESS</font color=blue> <font color=red>AMERICA</font color=red>
Reply to dhlucke
There are 1898 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Blu-Ray playback software recommendations?
By Rusting In Peace, 2 days ago:
My advice to you would to be avoid getting blu ray on PC it's totally annoying because of...
Best offers
Top experts
