Sound driver forwin -7 64 bit
hi all ,
i have developed an java Swing application which is capable recording audio and video on win-xp,7(32 bit) but now i want to launch it for win-7(64 bit) is there any change in sound fromat for 32 bit and 64 bit
or it works same for both type.
tahnks
jitendra :sarcastic:
3 answers Last reply
More about sound driver forwin
  1. jeet_shri said:
    hi all ,
    tahnks
    Should work the same!
  2. what shoud be the standerd and global frame rate for both win-7 32 bit and win-7 64 bit
    currently i am using
    Sample rate;- 44100
    Channel:-2,
    16 bit
    is it works with 64 bit
  3. FYI, it is Sample Rate, not Frame Rate.
    Both versions of Win 7 should process sound exactly the same and neither are limited to a single sampling rate.
    As long as the sound card/codec supports it, any settings you chose should work just fine.
Drivers Sound Driver Java Windows XP Windows 7
