I posted my system specs earlier on the motherboard forum and a guy by the name of fatburger saved me from alot of frustration of a audigy card. I just want to double check though. Ive come across some other motherboards though and I would like to know if they are decent or not. Well here they are:
AMD Athlon XP 2100+
Asus A7V333 (VIA KT333), Epox EP-8K3A+, Enmic 8TTX2+, or Gigabyte GA-7VRXP?
Seagate Barracuda 60 GB HD (7200 RPM)
Samsung PC 2700 DDR 512 Mb CAS 2.0
VisionTek Xtasy Ti-4600
Turtle Beach Santa Cruz
Klipch Promedia 4.1
Toshiba DVD_ROM (16X/48X)
Generic Floppy Drive
Lian Li PC-65 or Cooler Master ATC-200
Antec 400W Power Supply
Ethernet Card for Wireless Cable Modem Network?
Logitech Mouseman Dual Optical and Cordless Keyboard
Windows XP Home ED.
Well any more input would be great. Thanx alot. Also are the vendors at pricewatch viable, can they be reliable or not.
Laterz
I basically know zip about AMD mobos so I won't comment on that. One thing could be that Visiontek Ti4600. They are not the greatest cards for the price. I'd much prefer Leadtek. Also you may want a CD-RW. They are extremely useful I find.
I'd switch that Antec 400W out for an <A HREF="http://www.enermax.com.tw/products/switch-main.htm" target="_new">Enermax EG465P-VE FCA</A> without even thinking. The 400W from Antec is possibly the worse name brand PSU I have ever installed in a system. Even the 300W Antec is better than the 400W, in terms of failure rates.
Compare the specs between the Antec and the Enermax, and you'll see the difference. I can also tell you that between the two, the Antec much more lightly constructed, and you'll need a fairly heavy-duty power supply for this new system ... especially if you intend to add devices at a later date, like a second hard drive, additional cooling, or another optical drive. Having dual-fans and gold heatsinks on the power transistors for better heat dissipation within the PSU on an AMD system is also something I would encourage ... and this the Enermax has, while the Antec does not.
The Enermax costs more, but you'll be glad you made the change, later on. Having a decent power plant for your new system is an important item ... more so than many people seem to realize.
Alright, I looked into the leadtek. It looks like I could overclock it quite a bit. Thanx for recommending it. I read reviews on it as well, looks like a great card, thanx.
I also will consider getting a CD-RW. Ive heard that Plextor is one of the best.
<P ID="edit"><FONT SIZE=-1><EM>Edited by BigBiggist on 05/18/02 08:48 PM.</EM></FONT></P>
The enermax looks great. I havent heard about the antec. It just sounded good because it would have been bundled with one of my cases. Hopefully the enermax is a pretty quiet powersupply.
Thanx alot.
Also, thanx for your guys' input on pricewatch, i will be sure to use resellerratings while i use pricewatch.
I have also been told to stick with the ASUS motherboard. Does anyone have any experience with an asus mobo. Are they good?
Oh, and nice rigs toejam.
Thanx alot for your help guys.
<P ID="edit"><FONT SIZE=-1><EM>Edited by BigBiggist on 05/18/02 08:49 PM.</EM></FONT></P>
Omg, i have absolutely no idea what motherboard to get now. Ive heard horror stories about the asus, thats great. Ive also heard horror stories about the gigabyte and the epox. Cant find anything about the enmic though. Jeez, i love AMD but this is crazy, it makes me want to go with intel. If anyone has any good motherboard recommendations for my specs I would really like to know. I want a very stable system that can get very high frame rates. I have a max budget of around 1400. Ive already got a monitor so i dont have to worry about that. If there are mobos that support PC 3000 ram that run great i would really like to know about them. Please help.
Thanx
I have just read user reviews and stuff. Although it has gotten great benchmarks, I have heard that it is a pain to get those benchmarks to perform.
Im lookin at the A7V333 board and people are saying that they are having trouble with the RAID detection on some boards and they are also saying not to go with any creative sound card.
I read a review on pricegrabber and a guy said he lost 600 pts on his benchmarks when he upgraded to a A7V333. He also said he cant change the IRQ's. Another guy said he had serious power problems with a recommended power supply. He used recommened everything and it was very slow. He switched to gigabyte and it was fine.
ANother guy who gave it good reviews said he hasnt had any "real" problems yet. Yeah right, he said he had sound issues with configuring the onboard audio. He said that it could be easily fixed. I dont know though. I am new at building comps so I am probably being over cautious. I was recommended to use this board or an Epox board.
I hope they were right.
Hrm... I personally would rather go with any other chipset solution than a VIA. The VIA+SBAudigy is currently being blamed for frequent Morrowind crashes, as that is the only common thread for anything more than the bad coding. While that in itself doesn't incriminate VIA of anything, since it's still happening with later chipset revisions and the newest SB line, one can assume that either there is something going wrong in the pipeline. I personally use the ALi chipset, its rock stable, and the IWill XP333 rev 2.1 that's in the system I built for my friend is problem-free. That and I like to root for the underdog!
Maybe an audigy would be better with an ali chipset. My old comp is a thunderbird 1133 built around an Iwill KT266, whatever that is, VIA? I have a sound blaster live and the stupid thing is a pain. THe damned drivers get corrupt like there is no tommorrow and it sometimes decides it would like to crash. I am impressed with the rest of the Iwill, it is very stable. I just want a very fast and stable comp. Mainly for online gaming with high graphics, my old Voodoo 3 isnt cuttin it.and burning MP3's and listening to music. ALso for a school comp for college and stuff.
Well, I don't know what any of that stuff means. Oh well, it's working fine for me so far so I'll just wait and see. By the way, I have a question in the Graphics Cards forum if anybody would like to go over there and help. Thx, later!
OoOoOoOoO..... That's pretty harsh. I personnally like AMD systems and I'm sure a lot of people here do also. Just cause you prefer Intel more, you don't have to go around beating people over the head for no reason.
the issues with the gigabyte have been addressed now. the 7vrxp is a nice board, a decent performer and gigabyte are known for being absolutely rock solid stable. also the dual bios may save your ass during a bad bios flash...
ive run 4 different gigabyte mobos so far with no real problems. ive had trouble with asus boards but no experience with the epox. the epox is supposedly a great overclocker but seeing as you are running an axp2100 i dont see you being able to overclock very much so i would stick with the gigabyte for stability and the dual bios. also you get onboard raid with the 7vrxp
I'm out of my mind, but feel free to leave a message.
Juin made a good point. Do you really need that GF4 Ti4600? It is basically pointless right now. An overclocked GF4 Ti4400 would do the trick nicely. Some people may say that a Ti4600 overclocked would do even better, but I have to say not by too much. With that extra ~$100 you could get some more RAM or just save it for your next video card.
Fatburger! Sorry i didnt respond to your post, i had to work and go to my stupid high school. I really liked your help.Anyways,
Man u guys are studs, except for Juin or whatever the hell his name is. Thanx juin i like how u pretty much dissed the begeezes out of my system. J/K. Well all u guys are a big help. Im stickin with the Santa Cruz and I am going to buy a leadtek TI-4600 just to overclock it alot. Im also goin with the Enermax power supply. i found a really cool case though, its a kingwin KT-436, it is blue and silver with blue tinted windows. I will most likely go with an epox or a gig, or asus mobo, omg havent decided yet. I will also add a plextor cdrw drive. Windows XP would of course work best with the system. THanx for all your help guys. If anyone knows anything else just say so. Also, is abspc a good site to buy stuff from, mainly a prebuilt computer? I think i found some really good deals on a kick ass AMD, $1966, and Intel system, $2284. I already have a good monitor so I can use the excess cash to get the best processor from both companies. Oh, and juin AMD stomps the %$#@ out of an intel system.LOL bud.
Later all, thanx.
BigBig
<P ID="edit"><FONT SIZE=-1><EM>Edited by BigBiggist on 05/20/02 09:44 PM.</EM></FONT></P>
