Now, on top of all this I have two 80x80 mm case fans and a Thermaltake Volcano 7 HSF. In other words, cooling isn't a problem. However, when running 3DMark2001 or any rather intensive 3D game/application my system consistantly locks up, forcing me to hard reboot. I have a hunch that my 300 watt power supply can't handle all those hydro-hungry components and the video card is freaking when it doesn't get all the voltage it needs, resulting in a lock-up. How did I come to this as-of-yet untested conclusion? Read on..
I have a second computer that contains all my old components. Following are the specs for this system (System Two):
- ECS K7S5A motherboard (SiS 735 chipset)
- Inno3D GeForce2 MX200
- AMD Athlon XP 1600+
- 256 MB pc133 SD-RAM
- Quantum Fireball 7200 RPM 20 GB hard drive
- Sony 52x CD-ROM
- Sound Blaster Live! Value
- 300 watt OEM PSU (came with the cheap case)
This system includes an AMD approved HSF and no case fans. As you can tell, this second system would require much less power to run because of the lack of case fans, a slower HSF, slower RAM, much less powerful video card and an older motherboard. Now, I used this computer in conjunction with my newer one to run a series of tests to make sure none of my components in either system were faulty. Following are my test results:
- 2000+, GA-7VRXP, GF4 -- freezing in 3D apps
- 2000+, GA-7VRXP, GF2 -- worked
- 2000+, ECS K7S5A, GF4 -- worked
- 2000+, ECS K7S5A, GF2 -- worked
- 1600+, GA-7VRXP, GF4 -- worked
- 1600+, GA-7VRXP, GF2 -- worked
- 1600+, ECS K7S5A, GF4 -- worked
- 1600+, ECS K7S5A, GF2 -- worked
I figure it's fairly obvious that the configuration that isn't working is the most power hungry of them all. I'm going to buy a new PSU (350 watt at least) and see if that fixes anything. The only other thing I could think that the problem might be is an overheating northbridge on the motherboard. Handling all the transfers for a blazing fast processor, RAM and video card on one little chip with only a passive heatsink seems like it could cause a problem. Some manufacturers included a little fan on the northbridge because of this exact problem, but my good friends here at Toms Hardware said the Gigabyte GA-7VRXP didn't suffer from this heat-related quandary.
I figured I would post this here in case anyone else had any ideas. If you do, reply. If not, don't. Simple!
Maybe I'm asking something you already pointed out but, have you run the "2000+, GA-7VRXP, GF4 -- freezing in 3D apps" configuration with both PSU? If it hang with both, the problem is in the motherboard (I guess). If not, the PSU.
Just another suggestion: more Wattage doesn't mean better PSU. Look for a good quality PSU from a well-known brand, a no-name 400W can be worst than a reliable 300W. I am sure you can found some suggestions in other treats of brand/model PSU, or just ask about it.
I haven't run the "2000+, GA-7VRXP, GF4" configuration on both PSUs because I figured that if it didn't work on an Antec 300w PSU it sure as hell wasn't going to work on a 300w OEM PSU. However, it's worth a shot. Thanks for the suggestion -- I'll try it tonight.
RE: quality PSU -- If I get a new power supply it's going to be Enermax or Antec as I've read that they're the best of the best.
And you're testing these configs with the case open, correct? What was the temp reading on your motherboard? (Nice choices on some of those components by the way, but why not PC2700 or at least CL2?)
<font color=green> $1,300 for new PC + $150 for OC cooling = I get fragged smoother in RTCW</font color=green>
Yeah, I'm testing them with the case open. The CPU temperature is another weird thing -- the GA-7VRXP says the 2000+ and the 1600+ both run around 55 degrees celcius which is rather toasty but not too hot. However, when I put the CPUs in the ECS K7S5A it reports them as running around 41 degrees celcius. Either one of the boards is reporting the temperature wrong or there is something seriously wrong with the Gigabyte board.
As for the RAM, that's my next upgrade. I'd like to get some Corsair PC2700 CL2 but it's rather expensive. We'll see how it fits into the budget.. or rather the lack of a budget.
