Tom's Hardware > Forum > CPU & Components > CPUs > xp unlocking materials problem
Forum CPU & Components : CPUs - xp unlocking materials problem
I decided to unlock my XP-1900+ today so I went to go buy the materials. I found everything except the conductive stuff. I looked at Lowes and home Depot before just giving up. Does anyone have any idea where to look and what to buy?
And since I'm on the topic what voltages should I use to when I overclock to 2000+, 2100+, or possibly further.
thanks
Sponsored Links
i used the rear window deffoger fixer. you may be able to get it at kragen, but the one by my house didnt have any and they just looked at me funny once i explained what i was trying to do. i eventually found some at autozone. or you could look at some electronic shops for one of them circuit trace pens. you might find one at radio shack, try the small mom and pop stores though. check the pen before you leave the store to make sure its not dried up.
how do you shoot the devil in the back? what happens if you miss? -verbal
Reply to jihiggs
There are 765 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
