Why do I suddently have horizontal lines running on display? There are just two in the middle of the screen. Do I really need to replace screen. If so, can I replace by myself easily?
if you are asking if it's easy, then no it's not easy. If you've never disassembled a laptop before I'd recommend you pay someone who has to do the replacement.
Try an external monitor to verify that it's the screen that is at fault and not the hardware, but most likely it is the screen.
