Battery charged, but not working right
I have an Armada 100s by Compaq. When I installed a new compatible 3rd party battery in the control panel power management properties under the power meter tap the power status shows the plug ac power. Total battery power remaining 100%. Under #1 a battery icon shows it with a red X and 0% next to it. What could it possible be that won't allow the new battery to be used?
1 answer Last reply
More about battery charged working right
  1. Is there a driver needed to recognize the battery?
    Can you start your computer after first turning it off and removing the AC adapter?
    Other:
    1) update your BIOS if it's out of date
    2) look under Drivers and Software for your laptop to see if there are any drivers or software updates that might recognize the 3rd party battery
    3) Turn off your PC, unplug it and RESEAT your battery to be certain it's definitely snapped in there (I don't see how it could not be though)
Battery Power Laptops
