Tohiba satelite L735-10T shows amber light on power button even after
Tohiba satelite L735-10T shows amber light continuously on power button even after total shutdown
2 answers Last reply
More about tohiba satelite l735 shows amber light power button after
  1. hi,
    I'm not familiar with what amber light indicates, can you check your user manual?
    By total shutdown do you mean shutdown or standby?
    is this behavior the same with battery and without it?
    When did this problem first present itself?
  2. don know it just started 2 days back as i shut down my laptop the orange light comes on at the power light and was on till morning... chkd all the possible solutions
    none worked
Light Power Shutdown Laptops
