Hi! Any body can tell that is there any software in DOS or Windows enviroment, that can recover deleted Files. and if yes where can i find it and download it????????
Sponsored Links
Yes, just search Google using the keyword "undelete", and you'll see tons of related software. Most of them are not free though.
Reply to elzt
I found one on download.com the other day, search for "data recovery"
I d/l it at work, so I can't think of the name offhand
It's all good ^_^
Reply to namek0
You need Hiren's boot CD which IS free. And includes ALL the tools you'll need. Download <A HREF="http://homepage.ntlworld.com/hiren.thanki/downloads/bootcd.html" target="_new">here</A>
Quote :
Hiren's BootCD 3.2
All in one Dos Bootable CD which has all these utilities
Partition Magic 8.0
Best software to partition hard drive
Drive Image 2002
Best software to clone hard drive
Norton Antivirus 2003
For emergency when you cant boot to windows because of a virus
Norton Ghost 2003
Hard drive Cloning software, Similar to Drive Image
Ontrack Easy Recovery Pro
To Recover data that has been deleted/virus attack
NTFS Dos Pro 4.03
To access ntfs partitions from Dos
Bootmagic 7.1
This tool is for multi boot operating systems
and too many great dos tools
great collection of dos utilities
You can download it .iso inside
Download Size: 12.7 MB
You'll need a burning app like Roxio or Alcohol etc. to burn then boot off it :)
Psyko
<A HREF="http://forums.btvillarin.com/index.php?act=ST&f=41&t=421&s=205efc501496823a64ba7fbd37152ff2" target="_new">Psyko's Rig</A>
Reply to psykoikonov
Tom's Hardware > Forum > Applications > Other Software > Need Help
There are 1204 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
