AMD VISION Engine control center crashes
hello,
pardon my english im not great.
recently i have re-installed my windows 7 pc just to fix some things with my game (league of legends)
this game crashes very often and i have no idea why i get error and bugsplats etc..
but thats not my question i already asked on their forums still waiting for a reply and im investigating myself,
so what i have found the crashes could be related to CCC (catalys control center) and as tip i should disbable or enable a profile? well i have searching to find where this profile i found i should check under 3d Gaming application settings then there it keeps crashing everytime i click it...
so the problem is:
my CCC keeps crashing when i click on: 3D application settings.
i just can't open it.
and maby on a side note anyone has expierence with League Of Legends and could help me out there aswell?
ps: this is the crash note: Catalyst Control Center: Host Application has stopped working.
kind regards, dvdnext (dane, dutch)
4 answers Last reply
More about vision engine control center crashes
  1. What version of Catalyst are you using?
    it say's amd version: 13.1
    * i ment catalyst version ;)
  3. What are the specs for your system? Also, is your Windows install fully up to date?
    Be sure to provide the make/model number of your video card, CPU, motherboard, and power supply at a minimum.
    i knew how to find my spec's easy but i really cant find them right now... when i find something its not really readable like alot of codes could u tell me where to find it?
    i used dxdiag.exe but there is so much info wich isnt even important but i can copy it anyways:
    System Information
    Time of this report: 3/5/2013, 21:20:17
    Machine name: ALLERNIEUWSTE
    Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130104-1431)
    Language: English (Regional Setting: English)
    System Manufacturer: To Be Filled By O.E.M.
    System Model: To Be Filled By O.E.M.
    BIOS: BIOS Date: 06/26/12 22:24:35 Ver: 04.06.04
    Processor: AMD Phenom(tm) II X4 965 Processor (4 CPUs), ~3.4GHz
    Memory: 8192MB RAM
    Available OS Memory: 8188MB RAM
    Page File: 2866MB used, 13507MB available
    Windows Dir: C:\Windows
    DirectX Version: DirectX 11
    DX Setup Parameters: Not found
    User DPI Setting: Using System DPI
    System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
    DxDiag Version: 6.01.7601.17514 32bit Unicode
    Display Devices
    Card name: AMD Radeon HD 7800 Series
    Manufacturer: Advanced Micro Devices, Inc.
    Chip type: AMD Radeon Graphics Processor (0x6819)
    DAC type: Internal DAC(400MHz)
    Device Key: Enum\PCI\VEN_1002&DEV_6819&SUBSYS_27301462&REV_00
    Display Memory: 1770 MB
    Dedicated Memory: 2029 MB
    Shared Memory: 3837 MB
    Current Mode: 1920 x 1080 (32 bit) (60Hz)
    Monitor Name: Generic PnP Monitor
    Monitor Model: IPS224
    Monitor Id: GSM58D6
    Native Mode: 1920 x 1080(p) (60.000Hz)
    Output Type: DVI
    Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
    Driver File Version: 8.17.0010.1172 (English)
    Driver Version: 9.12.0.0
    DDI Version: 11
    Driver Model: WDDM 1.1
    Driver Attributes: Final Retail
    Driver Date/Size: 12/19/2012 21:08:04, 1151488 bytes
    WHQL Logo'd: Yes
Windows 7
