SonyVaio Recovery Problem
Hello,
I had a trojan virus and felt the most appropriate action to ensure it was totally gone was to restore back to factory settings.
I used the F10 recovery method as the virus left me unable to open Sony Vaio Recovery Utility.
It worked fairly successfully, but now has a dialogue box asking for me to insert the recovery discs or application discs, and opens the DVD drive. I don't have any recovery discs - the laptop came with software pre-installed and stupidly I didn't make a recovery disc.
It's not possible to skip this stage, but if I press Alt+Tab I can access the usual Start menu, desktop, etc.
I've tried putting in another software disc and installing that software to see if I can 'dupe' it into thinking I've done what it wants, but there's no fooling it!
Whenever I restart the laptop the same dialogue boxes come up asking for the discs.
The model is a VGN-FS315B.
Can anyone help?
1 answer Last reply
More about sonyvaio recovery problem
  1. more and more often in the last few years laptops come with the opertating systems pre-installed - nothing new there, but more importantly they remind you to create your own backup media as a top priority.... Im guessing you didnt do this ? You may be able to obtain a recovery disc from Sony, but they will need evidence of purchase etc.
    Make sure you dont have a seperate partition on your hard drive that containts the recovery files - judging by the prompt for a cd/dvd Im guessing you dont - doesnt hurt to check though
Data Recovery Virus Laptops
