Tom's Hardware > Forum > CPU & Components > CPUs > 300Mhz power supply with a P4 system?
Forum CPU & Components : CPUs - 300Mhz power supply with a P4 system?
Will a 300Mhz power supply be ok for an Asus P4T533-C and P4-2.0Ghz(400Mhz FSB) and PC800 RDRAM
Sponsored Links
300 what!?
ohh you mean 300watt power supply.
Should be fine.
<A HREF="http://www.anandtech.com/mysystemrig.html?id=9933" target="_new"> My Rig </A>
Reply to xxsk8er101xx
More preferable would probably be an Antec 330W TruePower or an Enermax 350W PSU. Depends on how many peripherals you've got.
:smile: Falling down stairs saves time :smile:
Reply to Chuck232
It's wattage, not MHz.
Check out <A HREF="http://www.pcpowerandcooling.com/maxpc/cases.htm" target="_new">this</A> chart for a good idea on what's needed. Remember to take your total and divide it by 7 and then multiply it by 10, so as not to put too much strain on the PSU.
<b><font color=blue>~ What do you mean "It isn't working!"...Now where's my sonic screwdriver? ~ </font color=blue></b>
Reply to camieabz
Wow, that is a fast PSU!!!
<font color=red>God</font color=red> <font color=white>bless</font color=white> <font color=blue>the</font color=blue> <font color=red>U</font color=red><font color=white>S</font color=white><font color=blue>A</font color=blue>
Reply to buddry
300w is fine...but it may limit your overclock (if you ever plan to)...
:eek: <b>L <font color=red>A</font color=red> e <font color=red>T</font color=red> a <font color=red>I</font color=red> K</b> :eek:
Reply to pr497
There are 852 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
