M11x Driver_power_state_failure on ntoskrnl.exe+eacd2
Hey people,
Im having some trouble with my M11x R2 It seems to blue screen every now and then sometimes under load sometimes not .... there are 3 other issues which have started up at the same time which may or may not be part of the problem but ill explain everything to see if it helps
Separate issue 1:
Flash programs seem to freeze on opening for a few seconds e.g. youtube will freeze when I open a video for about 2-3 seconds
separate issue 2:
Can seem to play games apon resuming from either sleep or hibernate, I have to reboot the computer completely to make them work again e.g. Starcraft 2 and many steam games will open in the task bar but not open up at all otherwise.... also cant use end task on it as it wont do anything
separate issue 3:
Just a quick one this time ... I cant turn the pc off through Shutdown it half powers down but never actually turns off.
Right now to the problem at hand,
I get a blue screen driver_power_state_failure which using bluescreenview on the minidump shows
100311-16473-01.dmp 03/10/2011 12:08:23 DRIVER_POWER_STATE_FAILURE 0x0000009f 00000000`00000003 fffffa80`08d73a10 fffff800`06494518 fffffa80`060f3440 ntoskrnl.exe ntoskrnl.exe+7cc40 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.1.7601.17640 (win7sp1_gdr.110622-1506) x64 ntoskrnl.exe+7cc40 C:\Windows\Minidump\100311-16473-01.dmp 4 15 7601 521,832
it seems to be happening quite a lot but if you need anymore information please let me know
1 answer Last reply
More about m11x driver_power_state_failure ntoskrnl eacd2
  1. I have the exact same problem, but on the alienware M17xR3... Does anyone have a solution?
Blue Screen Laptops
