I'm currently building a computer, my mother board is a EPoX 8KHA+ (KT266A) and the CPU that I'm using is a Athlon XP 1800+. Since this is my first computer, I have a few questions that I would like to ask. I suspect most of you work in the computer industry, so you should know alot more about this then I. 1) What kind of advantages do I get if I use thermal grease instead of the thermal tape that comes default on my Fan (cooler master | Athlon XP certified). If there is no major advantage (IE, faster benchmarks), then why do it? 2) How much care should I use attaching the mother board to the case (Enlight 7237), is the motherboard really that sensitive? 3) If there is any other key points that you could be so kind to alert me to before I begin building my computer, I would be very gratefull. Thank you. -Dave Wilson-
