hi
I just bought a lenovo ideapad y570 (laptop), but I'm worried, because the keyboard has the upper right corner, completely out, just around the corner,
the keyboard works perfectly, but it is uncomfortable that the keyboard is not quite right!
I'm from Costa Rica, and here there is no service for this brand of laptops, and was purchased through of newegg.com,
then
what can i do?
Is that bad?
what is your suggestion?
I invoke the warranty?
or is easy to fix?
I need a lot the laptop, because of my studies
and depend on it for almost everything!
and will be very bad for my having to send it back to united states to change me a new one!,
then you know any other solution?
thanks a lot!
Felipe
then
what can i do?
Is that bad?
or is easy to fix?
thanks a lot!
Felipe
