The following is to my knowledge, which admittedly is limited by the fact that I don't actually own a KT400 chipset mobo or DDR400 RAM.
<b>IF</b> you can get CAS2 DDR400 <b>and</b> you can convince your motherboard to actually run it at CAS2, then you're halfway there.
Even then though, you also have to up the FSB to 200MHz. (Or 400MHz for those who like to believe marketting.) You'll also probably have to unlock your Athlon to lower the multiplier to keep the clock from going insanely high.
And, of course, if you're going that far, you might as well water cool the bloody thing and overclock it to squeeze as much performance out of it as you can.
<b>Then</b> it'll all be worth the extra money.
For the less extreme, using CAS2 DDR333 and a FSB of 166/333 is easier. You might not even have to unlock the CPU to achive that if you can pick out just the right CPU to use.
Otherwise, it pretty much is a waste of money. There might be a minor performance gain noticed because:
1) The KT400 chipset might be tweaked a tiny bit bitter than the KT333 chipset.
2) The decreased latency and increased bandwidth without the FSB raising will still probably make a tiny difference to an Athlon.
Even then though, the performance gains will more than likely only be noticable by benchmarking and you would be completely oblivious to them during normal usage.
So is getting DDR400 a complete waste of money? It all depends on how you use it and how much you really expected to get from it.
<pre><A HREF="http://www.nuklearpower.com/comic/186.htm" target="_new"><font color=red>It's all relative...</font color=red></A></pre><p>
