Closed
Running compaq armada 1120 without battery
Last response: in Laptops & Notebooks
a b D Laptop
October 25, 2011 1:54:16 AM
if it has a power adapter that is on separate circuit I don't see why not
November 4, 2011 1:08:39 PM
I have an external power supply but the PC will not power up.
I have 2 flashing leds on the battery level indicator. I think the motherboard is defective.
I do not have any operator manual and the maintenance manual from the internet does not
show any description regarding the battery level indicator.
Best solution
a c 406 D Laptop
November 4, 2011 3:04:17 PM
Any laptop can be used w/o the battery as long as it is plugged into the A/C outlet (sometimes referred to as "the mains").
It could be that the motherboard is defective, or power connection inside the laptop is defective. At least that's my opinion. It's best to bring it to a technician to determine the fault.
November 4, 2011 4:09:34 PM
Thanks for your reply.
November 14, 2011 7:20:23 PM
Best answer selected by abmakeit2day.
a b D Laptop
November 14, 2011 9:11:06 PM
This topic has been closed by Area51reopened
