So i got all my components together for my new system, and started putting it all together last night. Unfortunately, it gets to "Verify DMI pool data..." and hangs.
The manual says to:
1. clear cmos
2. remove addon cards to see which causes
3. Change the CPU
Well, I've tried 1 and 2, and I don't yet have the ability to pull additional 2200+ precessors out of the air, so I'm hoping that someone might be able to help.
I've left the default settings in the bois for the multiplier, etc.
I set the memmory to 200mhz, but have tried scaling back to 133.
I'm wanting to try setting the bus/chip speeds manually, but haven't been able to find a good refernce for bus and multiplier speeds.
The memory is one stick of XtremeDDR PC-3200, which is supposed to be able to go to 200mhz.
I have disabled the onboard lan, sound, etc.
Could it be a memory compatibility problem?
What setting should I use?
Thanks!
Lost and confused with a shiny, $1000 hunk of parts, sucks.
The manual says to:
1. clear cmos
3. Change the CPU
Thanks!
