Tom's Hardware Forums » CPU & Components » CPUs » Help! These slotkets are driving me insane!
Word :   Username :
Bottom
Author
 Thread : Help! These slotkets are driving me insane!
Profile: Honorary Poster
More Information
My head is about to explode. I'm trying to gather information on the limited number of slotkets available out there. I have never used one before and I am completely confused.
I have an Abit BX-6 rev. 1 that has been sitting here for several months. I inquired about slotkets back when I got this board and it appears only rev. 2 can handle one. Last week I got my hands on a BH-6 rev. 1 which supposedly I can use a slotket in.
Here are my questions (please answer them without using big words):
1: I came across a Star Tech slotket for $11. <A HREF="http://www.compusa.com/products/product_info.asp?product_code=50115879&csearch=" target="_new">http://www.compusa.com/products/product_info.asp?product_code=50115879&csearch=</A> Has anyone ever used one of these? Are they decent?
2. Do I need an onboard voltage regulator like on the Power Leap or is that just for overclocking?
3. Do I use an FC-PGA or a PPGA and what the hell is the difference?
Coincidentally, PowerLeap is located about a 10 minute's drive from my house! I checked out their website and they list a slotket/1.4 Celeron combo for about $180. That seems a bit pricey. I don't want to put that much into a motherboard that's 4 years old! I'd really like to stay on the cheap.
Thanks in advance for any response. Remember not to use big words. :smile:
To start press any key. Where's the "any" key? --Homer Simpson.
Related Product
Profile: newbie
More Information
The MSI 6309 has adjustable vcore and works well; Abit slotkets can be unreliable. If your motherboard supports the 1.65v Coppermine you can buy one without this feature.
You should get a FCPGA slotket the one in the link is for the old Celerons.
I think Powerleap sells normal standalone slotkets as well, try their website again.
Profile: Tom's Hardware Team
More Information
The one in your link will work as long as your board revision supports Coppermine core CPU's (some early boards didn't support less than 1.8v natively, don't know if yours is affected). I'd try it. If it doesn't work due to the previously mentioned voltage issue, I can help you make your CPU run at 1.8v on that slotket. That Slotket supports all Coppermine core PIII's, which were available at speeds up to 1000EB (where the B stands for 133MHz FSB). Also, if your board supports the lower voltage natively, you could get a 1000E Slot 1 (notice no B, it's a 100MHz bus processor), which performs less (due to lower bus speed) and cost more (due to rarity) at $132 but wouldn't require PC133.
Basically, I can't tell you whether revision 1 of that board supported the lower voltage. But if you buy that slotket, I can tell you how to raise the detected voltage of a Coppermine core CPU to match an earlier board.
<font color=blue>You're posting in a forum with class. It may be third class, but it's still class!</font color=blue>
More Information
No, the one in his link supports PIII's.
Don't Overlook Da Simple Stuff
Profile: Forum Gigolo
More Information
OK buddy, heres the most info I could track down for you, and if this one won't do what you're after, I don't know what will, I temporarily shared your grief, this was a pain in the rear to track down, hope this is what you're looking for. Ryan
<A HREF="http://www.memoryshippers.com/shop/test3.asp?did=28&pid=922" target="_new">http://www.memoryshippers.com/shop/test3.asp?did=28&pid=922</A>
Details, Details, Its all in the Details, If you need help, Don't leave out the Details.
More Information
Thanks all. Maybe one of the problems getting my hands one one of these is that it is known as a slotket or a slocket. I've only been doing searches on slotkets!
I picked up a Celeron 1000 FCPGA and ordered some Mushkin PC133 Cas2. I went ahead and ordered the slotket from CompUSA. On their site it only says it's for PPGA and makes no mention of FCPGA. I hope this works.
One other thing. My BH-6 is a rev. 1.02. Do you think I'll have a problem with the voltage?
More Information
I couldn't find any info on the voltage, I just hope what you're getting works for you, the link I posted said it worked on all slot 1 M/Bs, but there was no mention of different voltage jumper settings, even though it had FSB jumper settings and other jumper settings. Ryan
More Information
Black_Cat, quit sweating it! The one you're getting will work for you, it auto detects CPU voltage and sets itself up, you set the jumpers for FSB, Processor type, and single or dual processors, so you are good to go. Ryan
PS I went to the manufacturers website and got my info from their spec. sheets.
Details, Details, Its all in the Details, If you need help, Don't leave out the Details.<P ID="edit"><FONT SIZE=-1><EM>Edited by 4ryan6 on 10/15/02 08:57 PM.</EM></FONT></P>
Profile: newbie
More Information
Says PPGA2SLOT1 maybe it's a misprint.
More Information
From the add:
Quote :
PPGA-to-Slot 1 CPU Adapter Card allows Socket-370 type CPUs (such as the Intel Celeron and Coppermine)
Quote :
Saves time and money when upgrading to a PC with a faster Celeron or Pentium III processor
More Information
I see your mistake, that's the part number, not a description.
More Information
Quote :
Okay, okay. It's only $11. I just feel like I'm going at it blindly. I have never used a slotket before. I'm a slotket virgin. I'm just getting a little shaky. I haven't played UT2003 in a few days!
Thanks for the link. It's too bad I didn't find that link before I bought the slotket from CompUSA. I could have saved $6!
All in all, if I can get this Celeron to oc to 1.33GHz for a total of about $130 I'll be quite happy. And if I don't you'll be seeing more posts from me. :smile:
Google Ads
News
Renesas: 90nm dual-core MCU for automotive to hit market by 2010
Published on August 18, 2006
Renesas Technology anticipates that its dual-core microcontroller (MCU) for automotive vehicles could hit the market by 2010 at the latest, and possibly as early as 2008. Read more
Studies show racing games promote risky driving
Published on March 15, 2007
Two separate studies, one in Germany and the other in the United Kingdom, have concluded that playing racing video games promotes risky driving behaviour, particularly among men Read more
Text Messaging Driver Charged In Hit And Run Death
Published on December 28, 2007
An allegedly text messaging driver has been charged in the hit and run death of a Taunton Massachusetts teenager. Read more
Craigslist Helps Rescue Cat From A True
Published on June 26, 2008
Denver (CO) - Apparently Craigslist can help rescue a stuck cat better than the local fire or animal control department. Read more
Latest Reviews & Articles
Atom, Athlon, or Nano? Energy-Savers Compared
Published on October 03, 2008
We compared Intel’s Atom 230 and VIA’s Nano L2100 processors hoping to find the best product for low-power applications. VIA is in the vanguard of performance. Is this enough to beat Atom? Read more
Interview: Bigfoot's Killer NIC, Exposed
Published on October 02, 2008
Since its release, the Killer NIC has garnered a reputation for being an extravagant and largely unnecessary add-on for the do-it-yourselfer. Seeking additional insight, we approached the card's designer. Read more
Seagate's 1.5TB Barracuda: Bigger And Better?
Seagate is the first hard drive vendor to offer a 1.5 TB drive in the 3.5” form factor. Meanwhile, WD sent us its RAID Edition 3 (RE3) drive. We tell you which is the best HDD choice today. Read more
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
