Archived from groups: microsoft.public.broadbandnet.hardware (
More info?)
Thanks for your suggestion, but I didn't have any problem
with the signal strength, I was configuring the laptop in
the same room as the base station, Windows shows
connectivity at full strength. I guess the problem is a
setup problem because the laptop can see and connect to
the hardware itself, just couldn't connect to the
network. The IP address on the laptop is either
169.xxx.xxx.xxx or 0.0.0.0, couldn't get a 192.168.2.x
assigned.
Tried static IP, MSNB recognized the static IP but still
didn't connect it to the network.
Works great with the cable, the only problem is I want to
use the laptop elsewhere in the house.
Any other suggestions?
>-----Original Message-----
>Hmmmmmm. Not sure if this will help you or not but I
just
>went through the whole MN-500 router and MN-510 USB
thing
>over the past week. Was getting nowhere each time I went
>about setting it up and getting a connection through the
>USB side. Main (new) computer and base station and cable
>modem all worked flawlessly, it was just that crazy USB
>adapter that refused to connect, even though it would
>show an excellent signal strength most of the time.
>Anyway, to be sure the adapter wasn't faulty I took my
>notebook over to the parents house (was their two
>computers being networked wirelessly) which has wireless
>built-in. Connected okay. Disabled the built-in,
attached
>the MN-510, let Windows ask for the CD, installed it.
>Worked fine.
>Back into the next room to try a Windows XP clean
install
>since that was going to be done eventually anyway. Had
>SP2 on it before, too, when it encountered that same
>incompatible message you (and others) had. I probably
>uninstalled and reinstalled the MN-510 eight times
before
>giving up, along with all networking and USB hardware
>drivers too. It was still not connecting after an hour
to
>get XP setup on a reformated disk!
>Now get this... my mother comes into the room to check
on
>progress and she says "Maybe if it were closer to the
>base station it would connect?". I had already moved the
>thing around some, and with them only 20 feet apart I
>figured it might be interference from a basement full of
>fluorescent lights not distance anyway. So she pulls it
>as far as it will stretch, a mere two feet farther than
>before and set onto the other end of the desk.
>Amazingly it saw the MSHOME (used all defaults in an
>effort to prevent confusion) network and almost
>connected. We moved the base station to the end of her
>desk too (fathers is the other computer). Retrying to
>connect a few times and it finally did. I couldn't
>believe it. The things are supposed to connect at up to
>300 feet in open spaces and what we eventually figured
>out from all this is that the initial connection must be
>extremely accurate and well-defined or else it fails.
>Once we had it going it had a 2 Mbps speed that dropped
>down to only 1 Mbps soon afterward. We actually taped
>down both the MN-500 and 510 to the desks so they would
>stay in position. Later I noticed the connection speed
>was up to 5.5 Mbps.
>Really goes to show this brand/model wireless device is
>finicky beyond compare. Since beginning to work on it I
>have read several messages from other people about lots
>of connection troubles with the MN 5** and 7** units. I
>never had a problem with the DELL Truemobile 1184 and
>1180 wireless router and USB adapter I use with my
>notebook and desktop and cable modem, although I did do
a
>release and renewel of IP at first so it would get to
>internet.
>Maybe you'd have to have been there when my Mom moved
>that MN-510 across the desk and is started to connect.
>You can literally almost see the MN-500 just 20 feet
away
>from where it had been all along. Maybe a bad antenna?
>But then why the strong signal most times, other times
no
>signal or no wirleless network? Something very glitchy
>about it, if you ask me.
>Hope no one got too bored reading all this.
>Best of luck to you all.
