I've just purchased a cool new Enermax case with a 350WT power supply, and I'm itching to buy some parts to fill it out. My current system is a AMD T-bird 900mhz, which I have been extremely satisfied with and has given me few problems. I also have an older 400mhz PII which has also been an excellent system and I've had no complaints with. But I'd like to upgrade to play some of the newer games with more speed, and just because building computers is a fun hobby.
I've been reading some of the articles here and it looks like Intel is the best, and the Intel P4 478 2.26 533 FSB caught my eye. However it's $185, not counting the motherboard and appropriate type of RAM. It would make a really sweet system if you had all the appropriate parts, I think. I'm also not sure if my 350WT power supply would be sufficient for this CPU.
The same vendor I got the $185 quote from also has the Athlon XP 2400+ at $199, but that's only a 266 mhz bus, correct? Again I haven't looked into the power requirements for this either.
So basically I was just wondering if anyone could give me some advice on a good CPU/mobo combo that would work with the 350WT power supply and cost around $300. I'm open to either AMD or Intel as I've had great sucess with both chipsets, but leaning towards Intel a bit more at this point based on the articles I've read here.
Also I'd be interested in a motherboard with built in sound and LAN support, I think that's a cool idea and less things to fiddle with. I'm also planning on getting a GeForce 4 128MB card, and a 120GB HD and that's probably it for expansions. Not sure on what type of RAM yet but at least 512MB. I'd like to keep the system simple and clean, so again would the 350WT power supply be able to meet my needs?
Thanks for any advice/replies.
