Toshiba Qosmio X505 q892 replacement LCD help.
Last response: in Laptops & Notebooks
I have recently come into possession of one of these marvelous machines, but the screen and HDD were done for. I've since replaced the HDD, and everything is working just fine, minus the display, (thank goodness for HDMI out!). Apparently it was hit or dropped pretty hard, as it is completely smashed and will require replacing. There's only one problem; I don't know which particular screen to get:
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias...
As you can see, there are quite a few different options.
I'm more than slightly confused, and I definitely don't want to get the wrong one, so I figured someone here would be able to give me a hand with this. Considering they're all practically the same, and every X505 model differed only in performance specs, would I be okay with any one of these?
Thanks for your time :)
Ask the community
