Solved
Burning DVD problems
Win 7 Ultimate 32bit, have tried Nero 10, InfraRecorder, Ashampoo Burning Studio 10, StarBurn, Smartburn, AVS disk Creator, Amok, all work intermittently making DVD's, all work makig CD's(data, have not tried audio), Lite-On SHM165-6HS, HSOE firmware, anyone else ever have problems, I am beginning to think it is the disks
5 answers Last reply Best Answer
More about burning problems
  1. Best answer
    "all work intermittently making DVD's, all work makig CD's"
    This could have been put better to explain your problem. I'll asume that it's failing intermittently making DVD's, but burns cd's ok.
    If that's the case then you have a faulty burner and it needs replacing, which is not very expensive.
  2. I just tried again with a new disk, it comes up with a medium error when I am using Ashampoo
  3. Take a look through this before replacing your burner - http://windows.microsoft.com/en-US/windows7/Troubleshoot-problems-with-creating-a-DVD-Video-using-Windows-DVD-Maker
    If none of the solutiions helped you, I am too leaning toward faulty DVD burner.
    Cassandra
    Microsoft Windows Outreach
  4. Best answer selected by Number13.
  5. well I'm not going to be able to get a burner till next month, darn, well thanks a lot for the advice
DVD Burner Windows 7
