Hi all,
I'm in the steps of upgrading my system, and I had a stupid question that needs answering.
I'm thinking of getting an AthlonXP 2100+, which has a 266MHz FSB. It's only $90.
I'm also thinking of getting an NForce2 board, which can support 266MHz and 333MHz FSB's.
Now, I want to get 333MHz DDR memory, because then in the future, when the prices on 333MHz FSB Athlons drops down to something reasonable (they're now around $300+), I could upgrade the system by just swapping in a new 333MHz FSB CPU.
Now, is it possible to run a 266MHz FSB CPU with 333MHz DDR memory, or does that screw up the frequency or synchronization between CPU and RAM?
If you could get me an answer quick, I'd really appreciate it!
Thanks.
Thanks.
