Tom's Hardware > Forum > CPU & Components > CPUs > cpu temp problem
hi guys, I recently purchased an Atholon Xp 2100+ with Gigabyte GA7VA. The cpu temperature dected is usually around 68 to 70 something degree celcius... is it normal or there is something wrong with my system?
btw i'm using the stock fan
thanx
Sponsored Links
yes that seems fairly high. However, if it runs stable then it is probably just a misreading.
<font color=blue> If it ain't broke, don't fix it...tweak it.</font color=blue>
Reply to slickstaa
Where are you reading these temps from? Are these idle temps or under load? When you installed your HSF what type of thermal conducting medium did you use (thermal tape, white paste, artic silver III ???).
The Men Behind the GUNS!
<A HREF="http://www.btvillarin.com/phpBB/viewtopic.php?t=327" target="_new"><b>MY SYSTEM</b></A>
Reply to Rubberbband
There are 1302 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
