Closed Solved
Showing a Red x Mark on the battery icon in the tatkbar ..So, plz suggest soluti
hi.....
I bought a Acer Aspire 4333 model laptop on 23/09/2010..,I am very satisfied with my Acer Laptop. But Now Showing a red X mark on the battery icon in Taskbar. and showing a message as “Consider Replacing your Battery”. I don’t know what happened , there is no any problem in charging.
So,please suggest solution for this problem
regards:
Mehbu Shereef
mehbu.shereef113@gmail.com
5 answers Last reply Best Answer
More about showing mark battery icon tatkbar suggest soluti
  1. hows your battery life off the charger? have you noticed a signifigang drop?
    one thing to try is drain it all the way down till it shuts off, then fully charge it to recalibrate the battery. you might also check if Acer has a battery test program, up has one for my laptop
  2. Best answer
    Hi,
    This is probably a case of bad battery; you probably need to replace it.
    This is a normal phenomenon for a Li-ion battery (the type you have) to malfunction after 12-24months of use, depending on the battery quality and how the user treated it.
    Here is a nice mini article I came across which helps to explain when to replace the battery
    When to replace your laptop battery?
  3. Best answer selected by Mehbu Shereef.
  4. Mehbu Shereef said:
    hi.....
    regards:
    Mehbu Shereef
    Solutions :-
    simply update with SP1 pack win7, and there will be option avilable to untick the issues.. thanks...........
    belive in LAPNOSYS.in
  5. Hi :)
    CLOSING due to age... but please start another thread if you are still having problems , which I will answer promptly...
    All the best Brett :)
Acer Battery Laptops
