Solved
Will a dead motherboard battery keep a 1450 solo from coming on at all?
Last response: in Laptops & Notebooks
Best solution
Motherboard Authority
Laptop Expert
Well if you can check all connections you can try that, any loose switches or cables. And make sure it's not the wall socket that went out from a blown fuse or something. Otherwise something died and it's so old it's not worth fixing. You can take the hdd out and put it in another computer if there's any files you need on it.
Ask the community
