Yes No
Ads
Tom's Hardware > Forum > Computer Brands > Dell > Inspiron 7500 power on problem
Forum Computer Brands : Dell Inspiron 7500 power on problem
Archived from groups: alt.sys.pc-clone.dell (More info?)
Hoping someone can help.Suddenly this wont power on.When the switch is
pressed the lights come on fan spins etc but no video output,then it
switches off and on constantly by itself..
TIA
Mick
Reply to mick
Mick,
Happened to me once. These are the steps I went through. Unplugged the
power cord and pulled out the battery, then pressed the power button. This
is supposed to discharge the system. Plug in power cord and try again. In my
case, same results. Next removed the floppie / DVD player and tried again,
same results. Next removed the hard drive and tried again, same results.
Next removed the RAM and tried again, BINGO! it booted up or at least went
further. Replaced each item one at a time and made sure it booted up. Lastly
I replaced the RAM memory and it .........booted up just fine. I would have
bet that the RAM had to be the culprit. So this story has a happy ending and
the laptop is still computing. :-) Hope your also works out well. Now you
didn't say if this is a laptop or a desktop, but if it's a laptop you may
want to check to make sure your power supply is putting out juice, it could
be possible that your battery could be almost dead.
Paul
"Mick" <mick@gotout.plus.com> wrote in message
news:41aaffda$0$23398$ed2e19e4@ptn-nntp-reader04.plus.net...
> TIA
> Mick
Reply to Anonymous
Good troubleshooting steps, Paul, but you should be aware that an Inspiron
is indeed a laptop. Also, due to its age, the battery should he the first
item checked.
If there is a flashing green / orange power indicator, your battery needs
removed / replaced.
"Paul Schilter" <paulschilter@comcast dot net> wrote in message
news:RtCdnSW1HYZbCDbcRVn-tQ@giganews.com...
> Mick,
> my case, same results. Next removed the floppie / DVD player and tried
> again, same results. Next removed the hard drive and tried again, same
> results. Next removed the RAM and tried again, BINGO! it booted up or at
> least went further. Replaced each item one at a time and made sure it
> booted up. Lastly I replaced the RAM memory and it .........booted up just
> fine. I would have bet that the RAM had to be the culprit. So this story
> has a happy ending and the laptop is still computing. :-) Hope your also
> works out well. Now you didn't say if this is a laptop or a desktop, but
> if it's a laptop you may want to check to make sure your power supply is
> putting out juice, it could be possible that your battery could be almost
> dead.
> Paul
>> TIA
>> Mick
Reply to Anonymous
- 0 +
Thanks for the help but its not the battery(tried without one),or the
psu(tried another one)not the memory(swapped it)pulled the
dvd/floppy,reseated the vid card,pulled the hdd,reckon it must be the cpu
"personalpages.tds.net/~rcsilk" <dick_silk@antispam.gov> wrote in message
news:41ab9acf_1@newspeer2.tds.net...
> item checked.
> removed / replaced.
> > Mick,
the
This
In
just
almost
> > dead.
> > Paul
> >> TIA
> >> Mick
Reply to mick
Oh yes, forgot one thing:
Underneath (like as in TAPED underneath) the palm rest section of a laptop
keyboard (not the keyboard itself, but the surrounding lower area) is where
the CMOS batteries are kept on some units. WHY they didn't use button cell
technology, I'll never know. Instead, some units use multiple-cell
rechargeable batteries that look like small round, sliced sections of a hot
dog. When these batteries stop recharging, your motherboard's CMOS / BIOS
settings go kaput, and -- well -- you *appear* to have one *sick* laptop.
All KINDS of errors can result from this condition, and if your keyboard is
3 years old or more, it's time to give them a check with the ol' volt meter.
Dick Silk -- The Computer Tutor
http://personalpages.tds.net/~rcsilk
for rates and online chat
- Are dog biscuits made from collie flour?
news:41abb4d0$0$18462$ed2e19e4@ptn-nntp-reader04.plus.net...
>> Inspiron
>> first
>> item checked.
>> removed / replaced.
>> > Mick,
> the
> This
> In
>> > at
> just
>> > story
>> > also
>> > but
>> > is
> almost
>> > dead.
>> > Paul
>> >> TIA
>> >> Mick
Reply to Anonymous
Dick,
Stupid me, next time I'll read the subject line a little better. The
computer I had the problem with was an Inspiron. Duh! Thanks for the
correction. :-)
Paul
> item checked.
> removed / replaced.
>> Mick,
>> This is supposed to discharge the system. Plug in power cord and try
>> again. In my case, same results. Next removed the floppie / DVD player
>> and tried again, same results. Next removed the hard drive and tried
>> again, same results. Next removed the RAM and tried again, BINGO! it
>> booted up or at least went further. Replaced each item one at a time and
>> made sure it booted up. Lastly I replaced the RAM memory and it
>> .........booted up just fine. I would have bet that the RAM had to be the
>> culprit. So this story has a happy ending and the laptop is still
>> computing. :-) Hope your also works out well. Now you didn't say if this
>> is a laptop or a desktop, but if it's a laptop you may want to check to
>> make sure your power supply is putting out juice, it could be possible
>> Paul
>>> TIA
>>> Mick
Reply to Anonymous
There are 2105 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What type of sound card does a dell dimentsion 8300 have
By Ubrales, 7 days ago:
Are the speakers turned OFF or disconnected? Check and make sure that the power adapter...
Best offers
