My new system suddenly locked today and then would not boot, wouldn't even post. I assumed the worst...fried/faulty CPU.
Basic specs are:
XP 2700+ (not o/c)
2 x Kingmax DDR333 256MB
Leadtek K7NCR18D Pro Nforce2 motherboard
GeForce 4 Ti4600
TT Volcano 7+ Heatsink/Fan
The system idles at about 42'C and has never risen above 49'C even under load, so I assumed the CPU hadn't fried. It must be a CPU prob though due to non post/video.
When I reseated the CPU and heatsink everything was fine, but when I put the case the right way up it crashed again with exactly the same symptoms.
The only thing I can think of is that the weight of the heatsink/fan is disturbing the CPU seating when the case is not flat, i.e. the heatsink is sliding when vertical and disturbing the CPU.
Is this possible?
I've made a wedge to stop the heatsink from moving, and so far everything is OK.
Are there any light weight heatsinks suitable for a XP2700?
Thanks in advance.
Basic specs are:
XP 2700+ (not o/c)
GeForce 4 Ti4600
Is this possible?
Thanks in advance.
