My friend currently has a 300W P3 733MHZ system (probably had that PSU when he built it), an Audigy, a TNT2 4X, a 20GB drive, home network, TV Tuner card and some other things.
His upgrade will be to a P4 2.4GHZ B with a P4PE, an R9500PRO, 512MB PC2700 DDR.
He claims it will run easily on 300W.
I have been telling him that this is not a good idea.
He will overclock it as well. First I don't know the PSU brand name nor does he, but it would seem to me that it would still be a much better idea to couple that power system with a 350W PSU from say Antec. At least at the same time he is having some future-proofing. He still persists that 300W is more than enough.
Tell me what you guys think, IMO 350W is needed.
<A HREF="http://forumz.tomshardware.com/modules.php?name=Forums&file=faq¬found=1&code=1" target="_new">The THGC Photo Album, send your pics and see others'!</A>
This just in, he took a pic of the PSU, it's an L&C PSU. Never heard of that brand. I would classify it as generic for now.
You'll need an adapter to use that old power supply with a new Intel board.
<A HREF="http://www.motherboardexpress.com/specs/spec_adv.cfm?ProductID=9048" target="_new">http://www.motherboardexpress.com/specs/spec_adv.cfm?ProductID=9048</A>
EDIT: The price for that adapter is insane. The link is just an example of what I'm talking about. You should be able to pick it up locally cheaper.
[-peep-].<P ID="edit"><FONT SIZE=-1><EM>Edited by LED on 12/18/02 05:56 PM.</EM></FONT></P>
Thing is, the P4PE has a 4-pin to 12V converter socket, so in fact any user with an old PSU can use that to his advantage than get a new 12V ATX PSU.
I don't know personally but that is an interesting question. Indeed he should check these out with his Asus Probe or MBM5.
