Solved
Toshiba satellite space bar problem
Hello, when I am typing normally the space bar does not respond unless I press harder than I do when pressing the other keys. I will look back at what I've typedandfind (like this) that many of the words are missing the spaces. The keyboard is not dirty, this is a fairly new computer. I'd like to know if this is a known problem with their keyboards, or if I get a different one, will I have the same problem? Thanks
2 answers Last reply Best Answer
More about toshiba satellite space problem
  1. Best answer
    Try changing the keyboard. Or remove the keyboard and see if the spring went loose (if there is one). Usually in case of a defective key, you could just change the one key from the service center for free if its available.
  2. Best answer selected by feathersthatfly.
Toshiba Keyboards Laptops
