Tom's Hardware > Forum > Smartphones & PDAs > Palmpilot > Battery replacement for Zire 72
Forum Smartphones & PDAs : Palmpilot - Battery replacement for Zire 72
Archived from groups: comp.sys.palmtops.pilot (More info?)
Hi,
I got me a Zire 72, with expired warrenty. The battery seems to go
crazy on me. After charging, the battery seems to be drained very fast.
Is there any place where I can have the battery replaced?
Thanks.
john
john's Profile: http://www.micromagiclabs.com/foru [...] ?userid=84
View this thread: http://www.micromagiclabs.com/foru [...] hp?t=23278
visit our palm forums at http://forums.micromagiclabs.com
Sponsored Links
It might be worth trying an "in-cradle reset" if you haven't tried that.
Basically, this is accomplished by hooking the device up to the cable
(or cradle), waiting for it to start charging, and then using a paperclip
or similar on the reset button on the back panel. This type of reset
resets the device like a normal soft reset but additionally resets the
charging circuit. It's a good first thing to try if your battery
doesn't seem to be taking a charge or holding a charge.
If that doesn't fix it, and if you feel comfortable taking apart the
device, you can buy a replacement battery from www.gethightech.com
for about $30 and install it yourself.
- Logan
Reply to Anonymous
There are 822 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
