G
Guest
Guest
Archived from groups: microsoft.public.broadbandnet.hardware (More info?)
I have a MN-700 and I will periodically lose connectivity
to it from my wireless connected laptops. The firmware is
up to date on the base and the computers are running XP
pro with SP2. When they lose the signal and I try to
reconnect they cant even find the base SSID and will try
to connect to another available signal. Then magically my
SSID will reappear and I will have to manually connect
them. This behavior has just started but I am hoping it
is not hardware related. I have rebooted the the base a
few times to see if that would cure the issue but it
returns. Not quite sure why its doing this. Thanks.
